Reply 20 of 27, by Dominus
- DOSBox Moderator
it's STILL not using the arch.
Please, open a new terminal window or tab, cd to your dosbox folder and do ONLY this (just copy paste into terminal)
export PATH=/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
export CC='/usr/bin/gcc-4.2 -arch i386'
export CXX='/usr/bin/g++-4.2 -arch i386'
export GCOV='/usr/bin/gcov-4.2 -arch i386'
./autogen.sh
./configure --disable-sdltest --disable-alsatest --with-sdl-prefix=/usr/local32
make clean
make
if it fails give me again the config log
(out of interest, nothing to do with the problem, is this in a VM? config log says that only 1GB of primary memory is there but two processors - that makes me think it'S a VM 😀)
