Debugger?
First post, by Tharos
Hi,
I tried to compile the CVS with the debugger...
calling configure with --enable-debug and everything compiles, dosbox is linked agains debug/libdebug.a - but after calling ./dosbox i see no debugger window?
Workt perfekt under debian at work - but does nothing on my mandrake 9.2 at home
what may be wrong?
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
the linking against debug/libdebug.a is always done. But in the normal case the lib is empty.
Anyway. Try looking in the configure output.
it should contain
checking curses.h usability... yes
checking curses.h presence... yes
checking for curses.h... yes
checking for initscr in -lcurses... yes
checking for initscr in -lpdcurses... no
if there are no's there then dosbox can't find your header files / libaries.
Water flows down the stream
Reply 3 of 5, by Dusten
Hi,
Sorry to up an old topic. I am trying to build a DosBox with heavydebug on. Where could I find the libcurses library to compile the DosBox in this mode? I couldn’t find a version the DosBox with heavydebug on.
I am working with MiniGW and MSYS on XP.
