First post, by emendelson
Sometimes, when I use DOSBox, the program running inside it acts as if one of the shift keys had been held down - sometimes the Ctrl key, sometimes, the Shift key. I usually have to exit DOSBox and relaunch to clear this out.
If it is possible to create a command that would clear all the shift states, so that I could attach it to a key and try to correct this problem without exiting, would anyone be generous enough to show me what the code would be?
Many thanks for any help with this.
