First post, by lucky7456969
Error	1	error C2198: 'SMPEG_new_rwops' : too few arguments for call	e:\jacky\downloads\dosbox\sdl_sound_visualc_srcs\sdl_sound\decoders\mp3.c	173	1	sdl_sound_dll
Thanks
Jack
Reply 1 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Make sure you have every lib sdl_sound needs compiled and installed as well. In this case it looks like smpeg is missing perhaps.
I never succeeded with SDL_sound on Windows (but that was four years ago) while it isn't that hard on OS X...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 12, by bloodbat
SDL_Sound needs a ton of external codecs you need to compile, so select what you want and discard what you don't, you need to satisfy dependencies or turn decoders off. I only use ogg and all three libraries (not incluiding SDL itself) compile just fine under Windows.
Reply 3 of 12, by lucky7456969
Could you show me how do I turn decoders off? Just like you, I'd like to have ogg installed as my personal preference
I thought there were #define's to exclude or exclude libs out.
Let me know
Thanks
Jack
Reply 4 of 12, by Dominus
DOSBox Moderator
If you use mingw you can do stuff like that through configure switches.
In msys cd to the folder with SDL_sound and run
./configure --help
Now you'll see available options. Configure will recognize which libs are installed on its own normally, though.
If you use visual c you will need to find other ways. I never used that
Reply 7 of 12, by lucky7456969
Hello,
Although I didn't want to have the rest of the codecs, strange enough, I am able to compile SDL_Sound by luck.
However, when I link it with VS2010,
I got the following error
Error	3	error LNK1104: cannot open file 'LIBC.lib'	E:\Jacky\Downloads\dosbox\sdl_sound_visualc_srcs\SDL_sound\visualc\LINK	sdl_sound_dll
I found that the project was pointing to the smpeg.h at ..\..\smpeg\smpeg
now I add one line before it, E:\Jacky\Downloads\dosbox\sdl_sound_visualc_srcs\SDL_sound;
Then it is able to be compiled, not linked.
Thanks
Jack
Reply 9 of 12, by lucky7456969
Error	3	error LNK2019: unresolved external symbol _ov_time_total referenced in function _OGG_open	E:\sdl_sound\SDL_sound\VisualC\ogg.obj	sdl_sound_dll
Error 4 error LNK2019: unresolved external symbol _ov_clear referenced in function _OGG_open E:\sdl_sound\SDL_sound\VisualC\ogg.obj sdl_sound_dll
Error 5 error LNK2019: unresolved external symbol _ov_info referenced in function _OGG_open E:\sdl_sound\SDL_sound\VisualC\ogg.obj sdl_sound_dll
Error 6 error LNK2019: unresolved external symbol _ov_open_callbacks referenced in function _OGG_open E:\sdl_sound\SDL_sound\VisualC\ogg.obj sdl_sound_dll
Error 7 error LNK2019: unresolved external symbol _ov_read referenced in function _OGG_read E:\sdl_sound\SDL_sound\VisualC\ogg.obj sdl_sound_dll
Error 8 error LNK2019: unresolved external symbol _ov_raw_seek referenced in function _OGG_rewind E:\sdl_sound\SDL_sound\VisualC\ogg.obj sdl_sound_dll
Error 9 error LNK2019: unresolved external symbol _ov_time_seek referenced in function _OGG_seek E:\sdl_sound\SDL_sound\VisualC\ogg.obj sdl_sound_dll
Error 10 error LNK1120: 7 unresolved externals E:\sdl_sound\SDL_sound\VisualC\win32lib\sdl_sound_d.dll 1 1 sdl_sound_dll
It seems to be errors and looking for the right libvorbis.lib
Thanks
Jack
Reply 11 of 12, by lucky7456969
Thanks, I finally sort out everything except this. My final final final error
extern "C" int _nhandle;
bool Network_CloseFile(Bit16u entry)
Bit32u handle=RealHandle(entry);
int _Expr_val=!!((handle >= 0 && (unsigned)handle < (unsigned)_nhandle));
//_ASSERT_EXPR( ( _Expr_val ), _CRT_WIDE(#(handle >= 0 && (unsigned)handle < (unsigned)_nhandle)) );
if (!(handle > 0) || ( !( _Expr_val ))) {
_doserrno = 0L;
errno = EBADF;
dos.errorcode=(Bit16u)_doserrno;
return false;
if(close(handle)==0)
NetworkHandleList[entry]=0;
DOS_PSP psp(dos.psp());
psp.SetFileHandle(entry,0xff);
return true;
else
return false;
}//bool Network_CloseFile(Bit16u entry)
Error	3	error LNK2001: unresolved external symbol __nhandle	E:\ykhwong\visualc_net\dos_files.obj	dosbox
