First post, by static-
When I try blood with cycles=max, core=dynamic, it runs perfectly smooth and uses 15% host cpu
When I try blood with cycles=max, core=normal/full, it runs very slowly and uses 15% host cpu
I would have thought host CPU would be the bottleneck for core=static, but that doesn't seem to be the case.
What it the bottleneck when core=normal or core=full ?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you have a multicore processor ?
(i7 ?) As this looks like one of the cores being maxed out.
Water flows down the stream
Reply 3 of 3, by ripa
static- wrote:
I do (4770k) .. but strange, process explorer with "show one graph per CPU" shows none of the cores are maxed out. I see 8, I assume 4 extra from hyperthreading.
Windows balances load between cores, so that's why you might see 50% on two cores instead of 100% and 0% for example.
