First post, by ryan4946
when running a part of the program im running in dosbox, I believe it creates 2 temp files in its directory, and this is failing, this part of the software isn't EXTREMELY necessary, but getting it running would be amazing. the error im getting is
warning: file creation failed: c:\alphapls\worklib.tl*
knowing the software, I believe it creates 2 files named worklib.tl1 and worklib.tl2 as temporary files for editing the tool library (they may be copies from the actual tool library which are name toolib.tl1 and toolib.tl2) any input would be greately appreciated!
