First post, by superfury
When I look at the I/O for setting the bit it says:
	If clear system is in word mode. Addresses are rotated 1 position up
343 bringing either bit 13 or 15 into bit 0.
When I compare this to the other VGA documentation, it seems correct.
But when I look at the int10_modes.cpp code it's reversed (set is word address mode and cleared is byte address mode) with M_CGA2? So this means that data of mode 06h is written as in word mode (CGA compatible), but usually read as a normal EGA/VGA mode, taking every 2nd set of 8 pixels from the incorrect index. So instead of 0xC2, this needs to be 0xA2?
Doesn't this bit in int10_modes.cpp need to be reversed? Or is the comment incorrect (also all VGA manuals I can find atm)?
UniPCemu Git repository
Reply 1 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
As I recall dosbox just cheats a bit internally with memory access with some internal video mode state and not all io bits are actually used.
Reply 2 of 4, by superfury
Won't that give problems with games relying on that bit to work correctly?
Reply 4 of 4, by TheGreatCodeholio
you should find more accurate emulation of word and dword bits in DOSBox-X, I've been making a lot of corrections to VGA memory model and raster emulation including one related to how the win95 boot logo saves and restores the screen.
DOSBox-X project: more emulation better accuracy.
DOSLIB and DOSLIB2: Learn how to tinker and hack hardware and software from DOS.
