Attempt to solve FILES= problems
First post, by Qbix
Rank DOSBox Author
DOSBox Author
I'm trying to solve the files= problems.
Herefore I need a list of applications/games that have problems with it.
I've tried The Legacy of Micropose. But it works fine.
Does anybody know more ? (preferable freeware and small, but any will do)
Water flows down the stream
Reply 7 of 35, by Xerxes
1. stonekeep is a _dos_ game
2. i don't have w95
3. i love dosbox...
Intel C2D E8500@3,6 Ghz, DDR2-800 2x2Gb Ram, MSI Radeon HD6950 Twin Frozr II/OC, Asus P5E Deluxe, Asus Xonar DX, HDD: WD 500AAKS x2, Windows 7 Professional 64bit
Reply 12 of 35, by Mortal
Hello everyone
@ Xerxes
The problems started only after you installed the patch or did you have them with the original CD installation? I have installed Interplay's aniversary version of StoneKeep and I am playing it now (unpatched) and I didn't have any problems. I 've made a profile for D-Fend. Here Is the conf:
[sdl]
XfullscreenX=true
fulldouble=false
fullwidth=0
fullheight=0
output=surface
hwscale=1.00
autolock=true
sensitivity=51
waitonerror=true
[dosbox]
language=
machine=vga
memsize=64
[render]
frameskip=0
snapdir=snaps
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=12000
cycleup=500
cycledown=500
[mixer]
nosound=false
rate=22050
wavedir=waves
blocksize=2048
[midi]
mpu401=true
device=default
config=
[sblaster]
sblaster=true
base=220
irq=5
dma=1
sbrate=22050
adlib=true
adlibrate=22050
adlibmode=adlib
cms=false
cmsrate=22050
[gus]
gus=false
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRADIR
[speaker]
pcspeaker=false
pcrate=22050
tandy=false
tandyrate=22050
disney=false
[dos]
xms=true
ems=true
[modem]
modem=false
listenport=23
comport=1
[Autoexec]
SET ULTRASND=
mount C "N:\"
mount D "K:\" -t cdrom
C:
cd\
cd INTRPLAY\STONKEEP\
call SK.BAT
exit
My system's configuration is: Win2K SP4, GB-8HIXP - PIV2.53, RAM 512 RAMBus, SB 5.1. Platinum, NVidia Ti4600.
And sorry for murdering the English language!
Why?
Reply 13 of 35, by Xerxes
@Mortal Yes, problems started after applying patch 1.2. I got original CD from 94 (game ver 1.05 i believe), not anniversary edit.
ps. 1.05 is working fine
Reply 15 of 35, by Mortal
@ Xerxes
I am sorry but I haven't found anything yet. I am still playing the 1.05 version of the game (The last time I played it was about 3-4 years ago). If I find anything, I 'll post a message.
Why?
Reply 16 of 35, by Maxx1234
Sorry if I repeat myself, but you can run Stonekeep v1.2 in DOSBox :
sk.bat can be run with a WIN95 parameter, I guess it initializes in
a special mode that does not check for the FILES parameter value.
Just get into the game installation directory, make sure you have
mounted the proper cd drive containing stonkeep disc and enter in the
command prompt:
sk win95
This should do the trick.
If not, post and I will try to help if I can.
Reply 17 of 35, by Xerxes
@Maxx1234 Yes, it works! Thx 😁
Reply 18 of 35, by damien
I was having problems with errors about FILES=30 when running tie fighter.
After putting in some debug info, it became obvious that the problem was that my HD copy of tie fighter was actually missing some files; it's just that the program was reporting the error as "make sure you have FILES=30 set" instead of saying "missing file xxx".
Once I reinstalled it correctly it worked OK.
So maybe all of these problems are simply badly installed programs?
Reply 19 of 35, by priestlyboy
Neverlock, which I used to crack Innocent but Gulity 1 works fine in DOSBox. Since that's how I was able to use it. 🤣.
Ieremiou
Helping Debug DOSBox.
