First post, by filosofem
Hello!
i'm using windows 7 x64 and i'm trying to compile a simple graphics example with Dosbox SVN-Daum. I'm using newest version of Dosbox SVN-Daum and my real dos hardware compiles it without any errors and example works. Dosbox 0.74 gaves that error too.
I hope my screenshot tells more than 1000 words.
Thank you.
    807.38 KiB
Reply 1 of 2, by ripa
According to google, that has something to do with exception handling, which is weird, because you're compiling C instead of C++.... try -fno-exceptions ?
edit: compiler might think upper-case .C extension means C++ 😁
http://stackoverflow.com/a/24774864
Reply 2 of 2, by filosofem
You are right. if i try to compile with GCC FOO.C -o FOO.EXE then it fails.
It needs to compile GCC FOO.c -o FOO.exe then it works.
Problem solved!
Thank you. 😀
