First post, by Gene Wirchenko
I was experimenting with starting up DOSBox to run an app and exiting. I used the -exit parameter which worked fine until I had more than one -c "<insert command here>" parameter. Then, the exit did not happen.
For a workaround, I tried removing the -exit and adding a final command of
-c "exit"
This worked.
I have also noted that from GW-BASIC, that a
command "exit"
does not terminate DOSBox as I would have expected.
