First post, by nachiketh
Hi,
This is my first post here, so I hope i'm not being naive 😵
I wanted to know how Dosbox actually works, i'm currently using Dosbox to run a win32 application from my Ubuntu machine and it works like a charm. The application I'm using uses the Serial Port to interface with a remote modem, I wanted to know how is this achieved on DosBox.
Cheers! 😁
Reply 3 of 4, by nachiketh
IIGS_User wrote:
How do you run a Windows 32-bit application from within DOS(Box)?
Its an .exe which runs on Windows, its not actually a Windows 32-bit application. Its a DOS application which makes MSDN calls internally. Hope i'm being clear 😕 apologies for the misunderstanding earlier as my assumption was wrong
collector wrote:
DOSBox is for DOS games. Wouldn't WINE be more suited to your needs?
WINE does nor serve my purpose as its not a Windows application, but a DOS application which runs on Windows. The following error is what I get:
winevdm: Cannot start DOS application Z:\dos\c\T176.exe
because the DOS memory range is unavailable.
You should install DOSBox.
Reply 4 of 4, by vytra
nachiketh wrote:
Hi,
I wanted to know, how Dosbox actually application I'm using uses the Serial Port to interface with a remote modem, I wanted to know how is this achieved on DosBox.
- - You must find DOSBox option, then you have to find the "serial ports" and change, say on COM1:
Serial1 = directserial RealPort: COM1
good luck!
