First post, by Tricky
- Newbie
While I was working experimenting to get a DOSBox wrapper set up for an old DOS Game of mine my output catcher caught THIS warning:
2016-03-01 22:29:27.057 DOSBox[57669:3504938] 22:29:27.027 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
It was caught on the moment DOSBox was launched (and running the DosBox binary directly from the unix prompt confirmed that it was indeed DOSBox that causes this), and frankly, nearly all Mac applications coded and compiled in an OS X version prior to El Capitan suffer from this.
