First post, by joprysko1
I'm attempting to use the current DOSBOX SVN and I want to have the NE2000 patch installed. I'm attempting to build it on a Raspberry Pi 3. I'm planning on running a BBS that requires a packet driver installed, as it has it's own TCP/IP stack. I had tried building both the HAL9000 MB6, and DOSBOX-X, but both appear to use libraries that will only run native on x86 processors. I'm relatively new at doing anything with C++, so the collective knowledge of Google can only get me so far. I have not been able to find the actual "how" of adding in the patch, plus I've had difficulty finding the NE2000 patch, as several sites show it, but have dead links to where it was.
I also apparently don't have permission to post in the DOSBOX Patch forum, so I figured this was the next best spot.
Thanks,
Joe
