First post, by nahum
Intel OSX build compiled by thedoctor45 BUG report
What more DosLynx needs in DOSBox is:
‘NE2000 Ethernet Passthrough’:
http://users.ohiohills.com/fmacall/
The dosbox.com DOSBox 0.74 don't seem to be offered with that.
Their focus is old DOS games, which don't need Ethernet communications.
The Hal Megabuild 6 DOSBOX versions are dated.  But, have been found to work well in Linux and Windows wired connection.  But, not with a Windows WiFi connection.  The W(in)PCap documentation claims that is due to a limitation in windows.  These are discussed at arcor.de .  See URL.
http://home.arcor.de/h-a-l-9000/megabuild.html
Also given, there is a link to a Megabuild 6 DOSBox version made for the Intel based Mac, which has been tried and can NOT connect.
Even the NE2000 Ethernet Patch documentation claims builds on Mac do NOT work!
Perhaps this link sheds some light on the Mac problem:
https://stackoverflow.com/questions/15039551/ … n-mac-os-x-in-c
Q: Is there any change getting functional ‘NE2000 Ethernet Passthrough’ on the Intel OS X MacBook Pro Maverick?
nahum
Reply 1 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You might get further if you run these builds with sudo and a disk image you boot in Dosbox. Otherwise normal Dosbox doesn't support that at all and you need to compile a version yourself.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 9, by nahum
Dominus,
You're saying MB6 for MAC with ne2000.com, inorder to connect, needs to be RUN w/SUDO & 'DISK IMAGE' I boot in DOSBox.
I would need a 'HINT' pulling this off on a MacBook Pro. I do not feel comfortable at its CLI using SUDO, nor the disk image you speak of I boot in DOSBox.
nahum
Reply 3 of 9, by nahum
There appears to be a lot of renewed interest in MegaBuilds and this one peaked my interest, since it was reported functional
on the same platform as mine, OS X Maverick:
DOSBox SVN Daum build for OS X
http://ykhwong.x-y.net
I just tried to launch it and this error was trapped:
MacBook-Pro:$ /Users/mac/Desktop/20150125_i386/dosbox ; exit;
dyld: Library not loaded: /opt/local/lib/libSDL-1.2.0.dylib
 Referenced from: /Users/mac/Desktop/20150125_i386/dosbox
 Reason: image not found
Trace/BPT trap: 5
logout
[Process completed]
**Supported platforms: OS X (Confirmed to work on OS X Mavericks)
Q: Can this missing dependency be installed and how?
nahum
Reply 4 of 9, by Dominus
DOSBox Moderator
Search the forum for solutions with Daum, but Daum is buggy and its OS X version terrible.
And further, all these non-standard builds are not supported here - for help write the people who made them available.
Reply 5 of 9, by nahum
I'm NOT a programmer, so w/o reinventing the wheel, how can ‘NE2000 Ethernet Passthrough’ patch be added to this functional, fully automated build script for current SVN DOSBox for OS X:
https://github.com/emendelson/OneStopDOSBoxOSX
Yours,
nahum
PS. Micro has NO ethernet, only WiFi
Reply 6 of 9, by Dominus
DOSBox Moderator
you would need to patch the dosbox source. But AFAIK that patch only works with ethernet connection, not WiFi.
Merged back into this topic.
Reply 7 of 9, by nahum
Dominus,
I found this recent linux thread w/same goal in mind:
Re: Building DOSBOX SVN with NE2000 support for RPi 3
. . more details needed to patch the current SVN DOSBox SRC, under mac.
Ethernet/Wifi doesn't matter, since a hard wired ethernet adapter is available for mac and will confirm interface works, in shop, before purchase.
Faithfully,
nahum
Reply 8 of 9, by Dominus
DOSBox Moderator
Well, ethernet/wifi DOES matter since you need to have it hard wired when you try it.
Reply 9 of 9, by nahum
Dominus,
Found this updated ne2000 network adapter patch designed to work with the latest SVN dosbox:
https://sourceforge.net/p/dosbox/patches/238/
Basic HowTo 'cookbook' on integrating this update into the latest SVN dosbox SRC:
http://nerdlypleasures.blogspot.com/2014/02/p … -beginners.html
. . .please connect the "patch -p0 < ne2000_27_11_10.diff" dots, so the latest SVN builds as usual.
nahum
* BUG located in ne2000.cpp, line 1287, right after a call to mcast_index
