Yesterplay80 wrote:So far nothing of sorts is implemented, neither in vanilla nor ECE DOSBox. I'll look into it, maybe I can add this feature if it doesn't break anything (the "patch" is based on 7 year old code, it might not work with newer releases of DOSBox).
Yesterplay80 wrote:Assuming you were talking about this thread earlier, I implemented the changes Hidden Asbestos made into a current ECE build. Please download the binary here and try it, if it works as you intended, I'll keep the feature in future releases of DOSBox ECE.
chenke wrote:Sorry, I want to ask a silly question about DosboxECE config:
How to set fluidsynth in dosbox.conf correctly?
I tried this, but failed to load sf2 in a WIN10 notebook:
[midi]
mididevice=fluidsynth
midiconfig=dsound:8MBGMSFX.SF2
fluid.soundfont=D:\DOSBOX\SF2\SC55.SF2
Yesterplay80 wrote:chenke wrote:Sorry, I want to ask a silly question about DosboxECE config:
[midi]
The soundfont is specified with fluid.soundfont, not with the midiconfig option, for example like this:
- Code: Select all
There is no need to specify Direct Sound in the Windows version of DOSBox, because it is used by default, so in this case just leave the midiconfig option empty.
If you are upgrading from vanilla dosbox and don't see the additional options in the conf-file(s), make sure to rebuild it/them with "config -wc" at the dosbox prompt.
Delfino Furioso wrote:there is no mention of the deadzone patch anymore: have you removed it from your builds?
thank you for this project, btw
Yesterplay80 wrote:FYI: DOSBox ECE r4068.2 now uses mt32emu from the freshly released MUNT 2.3.0.
telanus wrote:Yesterplay80 wrote:FYI: DOSBox ECE r4068.2 now uses mt32emu from the freshly released MUNT 2.3.0.
any chance for a linux build?
Ant_222 wrote:But, as far as I know, Yesterplay80 is providing ready-to-build sources for ECE. Whoever can build vanilla DOSBox on Linux, should be able to build ECE using the same procedure.
