DOSBox ECE (for Windows & Linux)
Reply 1120 of 1369, by 7F20
lukeman3000 wrote on 2020-09-03, 00:03:
Thanks; just checked out that link. It looks like the pixel perfect implementation in ECE may still be superior in at least some ways. In which case, is ECE version r4301 still the most stable and feature-complete release containing ant's pixel perfect patch?
If you look back in this thread, there's a big to-do when Ant's patch was broken and they say what the last version with it is.
Reply 1121 of 1369, by KainXVIII
KainXVIII wrote on 2020-09-02, 21:43:
lukeman3000 wrote on 2020-09-02, 21:21:
Hi guys; just looking for some clarification - […]
* ECE no longer has ant's pixel-perfect support, but it can be added?
* Does the latest version of DOSBox (0.74-3) have ant's pixel-perfect?
* Is r4301 still the latest version of ECE that is the most feature-complete and stable? (presuming it includes pixel perfect as well?)
* Lastly, and this may be extending beyond the scope of this thread - does ScummVM now support some kind of pixel-perfect scaling? And furthermore, if so, what reasons might there be to continue playing games with DOSBox as opposed to ScummVM from a practical/functional point of view? I like DOSBox; I'm just wondering what differences (noticeable by the user) there are in the gaming experience between the two, at this point in time.
Pixel-perfect support can be added through shaders https://github.com/tyrells/dosbox-svn-shaders
ScummVM is usually better and have pixel-perfect scaling, but some games are not 100% compatible (https://www.scummvm.org/compatibility/), so expect a bunch of bugs compared to pure dosbox emulation.
In what ways?
Reply 1122 of 1369, by Yesterplay80
New release: DOSBox ECE r4367, now with MUNTs mt32emu in version 2.4.0!
https://dosboxece.yesterplay.net/
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
Reply 1123 of 1369, by KainXVIII
Yesterplay80 wrote on 2020-09-23, 07:14:
Huh, what's new in 2.4 version of munt? 👀
Reply 1124 of 1369, by _Rob
KainXVIII wrote on 2020-09-23, 14:54:
google...
https://github.com/munt/munt/blob/master/mt32emu/NEWS.txt
2020-03-29:
2.4.0 released.
* In addition to already existing options intended to improve
audio output quality in contrast to somewhat degrading emulation
accuracy, the two more quirks of LA-32 are now configurable.
NicePanning enlarges the allowed value range for the pan setting,
providing for smoother panning.
NicePartialMixing disables occasional counter-phase mixing of partials
making the timbres that contain closely sounding partials be
mixed in a more predictable way.
* Improved emulation of the pitch overflow quirks of the MT-32 GEN0
by disabling the upper-bound check that is only applied during the base
pitch calculations by modern units. Specifically, this fixes the "starfall"
timbre playing at wrong pitch in the WILLY BEAMISH intro when using
ROMs of the MT-32 GEN0 (discovered by eddieduff at Sourceforge).
* Fixed compilation errors when setting various preprocessor definitions
intended for debugging.
* Converted compiler definition MT32EMU_REDUCE_REVERB_MEMORY to a runtime
configuration option. This allows the client to ensure that reverb mode
changes are safe for rendering in a realtime thread.
* Improved the implementation of the internal MIDI event queue. Notably,
added a new storage mechanism for the payload of SysEx events that
does not require memory allocations while pushing events to the queue.
Reply 1125 of 1369, by KainXVIII
_Rob wrote on 2020-09-23, 15:39:
google...
Interesting, i wonder why there are no 2.4.0 release on sourceforge page https://sourceforge.net/projects/munt/files/munt/
Reply 1126 of 1369, by Yesterplay80
KainXVIII wrote on 2020-09-23, 16:11:
Because the project moved to GitHub: https://github.com/munt/munt
Reply 1127 of 1369, by KainXVIII
Yesterplay80 wrote on 2020-09-23, 20:05:
Thanks! But i can't find compiled version anymore (i mean installation files) 🤔
upd - found my answer
Sure thing, 2.4.0 is upcoming. I'm working on improvements in the UI application atm, and when it's done, the release will be rolled out.
Reply 1129 of 1369, by realnc
awgamer wrote on 2020-09-24, 03:56:
I remember munt being cpu heavy making it being a separate process a good thing. Has it become efficient enough to live in the same process with little impact or added as a separate thread?
Games that actually support MT-32 are old enough as to not place any serious demand on cycle count. So unless you have a very slow CPU, having Munt in the same process, or even same thread as the dosbox emulation thread, has never been an issue.
If you're on a very slow CPU (I'm thinking of like 2GHz CPUs fron the 2000's), then stand-alone Munt is better, yes.
Reply 1130 of 1369, by 7F20
realnc wrote on 2020-09-24, 15:33:
Just for reference, I use mt32emuqt with a debian varient on a Raspberry Pi, and it's absolutely no problem on a RPi3 or above. I think they say the CPU is equivalent to a 2GHz Pentium 4, very broadly speaking.
Reply 1131 of 1369, by realnc
7F20 wrote on 2020-09-24, 18:03:
mt32emuqt is stand-alone munt.
Reply 1132 of 1369, by _Rob
@Yesterplay80 just a heads up.
As I'm sure you know, dosbox-ece for Linux is currently compiled against libfluidsynth.so.1. However the upcoming Fedora 33 instead ships with libfluidsynth.so.2 and as such dosbox-ece no longer works. The user will get something like:
dosbox: error while loading shared libraries: libfluidsynth.so.1: cannot open shared object file: No such file or directory
Fedora offers no compat library either for backward compatibility with libfluidsynth.so.1
Presumably other Linux distributions will also be switching to v2 in the near future.
I ran into this same problem with dosbox-x. However with a simple re-compile against libfluidsynth.so.2, dosbox-x was working again.
Also, in the logs of dosbox-x I get the following messages:
fluidsynth: error: Unknown numeric setting 'audio.periods'
fluidsynth: error: Unknown numeric setting 'audio.period-size'
fluidsynth: error: Unknown string setting 'synth.reverb.active'
fluidsynth: error: Unknown string setting 'synth.chorus.active'
So it seems that some of the settings are no longer valid.
Reply 1134 of 1369, by Yesterplay80
7F20 wrote on 2020-09-30, 04:31:
Is that different from regular Munt?
MUNT is just the whole package, including the MT32 emulator, a gui, etc.
Reply 1135 of 1369, by realnc
realnc wrote on 2020-09-24, 18:11:
We use the term "stand-alone munt" to refer to running mt32emuqt or mt32emualsadrv or mt32emuwin32drv and then configuring dosbox to output to that through a MIDI port.
"Built-in munt" on the other hand refers to using a patched version of dosbox (like dosbox-ece) that can directly emulate the MT-32 itself rather than offload that work to another process or driver through a MIDI port.
Both work, but on very old and/or very weak multi-core CPUs, using a stand-alone version of munt can be preferable.
Reply 1136 of 1369, by 7F20
realnc wrote on 2020-09-30, 20:06:
Ok. Thanks for the clarification. I didn't realize that there was anything functionally different about the "baked-in" munts. I thought ECE or other were just packaging munt with their distro.
Reply 1138 of 1369, by PoulpSquad
Hello,
I'm having a hard time setting cycles.
I'm trying cycles=auto 5000 90% but when I run a protected mode game like Doom, cycles drop to 90.
I tried also cycles=auto 5000 90% limit 200000 with the same result, and I'm stumped.
I'm looking for some advice please.
DOSBox ECE r4367 on Windows 10 x64.
Reply 1139 of 1369, by Qbix
Rank DOSBox Author
DOSBox Author
can you attach a configfile with that problem ? As I can't reproduce it at my place. (using the non-ECE code)
Water flows down the stream
