DOSBox ECE (for Windows & Linux)
Reply 1400 of 1409, by villeneuve
Yesterplay80 wrote on 2021-11-02, 10:12:
Yesterplay80 wrote on 2021-09-24, 09:50:
I'm hosting my website on my NAS at home and since the latest update, it became basically unusable. 🙁 So, until I or Synology doesn't resolve this problem, please get the latest version of ECE from my Google Drive here:
https://drive.google.com/drive/folders/0BxEUS … 7mweueRbc7T4M8g
Sorry about the inconvenience!
I finally replaced my NAS with a new one and the ECE homepage should be reachable much better again!
There seems to be an issue though currently.
Reply 1401 of 1409, by Yesterplay80
villeneuve wrote on 2021-11-05, 16:10:
What kind of issue? Here everything looks normal currently.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 1402 of 1409, by villeneuve
Hm, I've now actually read the error message instead of just suspecting a 404 error. The issue is with the SSL connection which as I've now found out only happens when using my old Firefox (56.0.2). The exact error message is:
SSL_ERROR_PROTOCOL_VERSION_ALERT
Accessing the ECE homepage in a current Waterfox works though. So unless you're also targeting outdated browsers it's not an issue on your side.
Reply 1404 of 1409, by Yesterplay80
Should be working again. Note to self: Always update your DDNS settings after changing your DDNS password. 😉
However, there's nothing new on my site.
Reply 1406 of 1409, by morphinejh
Yesterplay, I use your source regularly to keep a hardware OPL modified version of DosboxECE running on Linux. Long story short I'm innately familiar with a lot of it at this point.
I noticed what I think is a copy/paste error around line 673 in (r4469):
/src/hadware/adlib.cpp
case MODE_DUALOPL2:
//Not a 0x??8 port, then write to a specific port
if ( !(port & 0x8) ) {
Bit8u index = ( port & 2 ) >> 1;
DualWrite( index, reg.dual[index], val );
} else {
//Write to both ports
DualWrite( 0, reg.dual[0], val );
DualWrite( 1, reg.dual[1], val );
break;
else if (oplemu == "nuked") {
handler = new NukedOPL::Handler();
Seems the NukedOPL handler is being initialized in a PortWrite() function.
Reply 1407 of 1409, by Yesterplay80
I'm currently compiling r4470 because the diff for the NukedOPL patch didn't apply correctly after the changes introduced in r4468 and I had to update my patch first. Download the new source in a few minutes and try again, please!
UPDATE: All versions of r4470 are online!
Reply 1408 of 1409, by morphinejh
Yesterplay80 wrote on 2021-11-17, 20:14:
Works great!
Reply 1409 of 1409, by zirkoni
FYI, DOSBox ECE is available from AUR: https://aur.archlinux.org/packages/dosbox-ece/
There were some annoyances in installing the package:
- The package version is old (r4465 vs 4470)
- The source download link is wrong (partially because of the old version but looks like the URL doesn't work even if you edit the pkgVersion)
- The installed binary is named "dosbox" which conflicts with other DOSBox installations (like SVN). I renamed the binary to dosbox_ece
- There was a spelling error in the created desktop-file (dosbox-eve)
https://www.youtube.com/user/zirkoni88
