DOSBox ECE (for Windows & Linux)
Reply 1440 of 1447, by zirkoni
abandon2022 wrote on 2022-04-30, 07:51:
pci_bus.cpp:29:10: fatal error: ..\ints\int10.h: No such file or directory
29 | #include "..\ints\int10.h"
https://aur.archlinux.org/cgit/aur.git/tree/b … ff?h=dosbox-ece
And probably also need this:
https://aur.archlinux.org/cgit/aur.git/tree/l … ff?h=dosbox-ece
https://www.youtube.com/user/zirkoni88
Reply 1442 of 1447, by zirkoni
It's just a few lines, you could easily do the changes manually.
Or download the diff-files and use the patch command in terminal:
patch -p1 < backslash-fix.diff
patch -p1 < linux-fix.diff
Reply 1444 of 1447, by Yesterplay80
Thanks for pointing out those issues, it seems those were introduced when I switched back from using the patch embedding the external Glide wrapper support. The patch only adding the internal wrapper is older and still had those two issues. Sorry about that! I fixed them just now so the source should compile now.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 1445 of 1447, by YaketyYakumo
Having what is probably the same joystick issue that was just mentioned - the POV hat isn't recognized by the keymapper if joysticktype is set to fcs.
Setting it to auto works fine, it's just FCS mode that's broken.
Basically it's currently the opposite of how it is in vanilla DOSBox.
Reply 1446 of 1447, by rolloLG
YaketyYakumo wrote on 2022-05-16, 03:25:
You got it! 👍🏻
Switching to "joystick=auto" instead of fcs fixes my issue with DPAD/POV-HAT digital joysticks and recent builds of DOSBox ECE!
@Yesterplay80
Reply 1447 of 1447, by dosmax
Just wanted to add my voice to the list of those who would very much like the Glide wrapper support back.
Demand might not be high, but that's probably just because most don't know how much better an advanced wrapper like dgVoodo0 with its unmatched resolution/antialiasing etc. options is compared to the integrated OpenGL patch. Perfectly understandable that you want to keep your build as clean as possible, but in this particular case the current solution is just no match for what has been possible until the Glide wrapper support was removed. dgVoodoo truly plays in a league of its own.
