Dosbox vs Qemu+Freedos
First post, by divinity
Dosbox and Qemu are about the same speed ( 15-25 FPS in Quake 2 Dos (320x200 resolution) http://dk.toastednet.org/Q2DOS/ ).
But when i enable KVM for Qemu i get 80-85 FPS at 800x600. http://wiki.qemu-project.org/Features/KVM
Would it be possible to implement KVM for Dosbox?
My PC and OS: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with a GTX 760 - Arch Linux x64
Reply 1 of 7, by awgamer
qemu+kvm is essentially virtualbox. virtualbox took qemu as its base and uses hardware virtualization features, kvm is hardware virtualization features bolted to qemu.
https://docs.google.com/spreadsheets/d/1lvF9n … pNU/edit#gid=12
Not the same thing but wine has integrated dosbox
https://wiki.winehq.org/DOSBox
As for your question, yes it's possible, but not the focus of dosbox so with the source available it'd be up to you or someone else to implement such an integration and it has been talked about before.
https://github.com/joncampbell123/dosbox-x/bl … 20driver%29.txt
https://lwn.net/Articles/658743/
Reply 4 of 7, by DosFreak
divinity wrote:
Dosbox and Qemu are about the same speed ( 15-25 FPS in Quake 2 Dos (320x200 resolution) http://dk.toastednet.org/Q2DOS/ ). But […]
This isn't a competition. Qemu has different goals than DOSBox.
Use the original binary or a port for your host OS for Quake 2.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 6 of 7, by Ringding
Because with KVM, it’s the hardware doing its job at full speed.
DOSBox does not use hardware virtualization for many (good) reasons.
- It can run in a virtualized guest OS
- It can run on non-Intel systems
- It can probably provide a better debugging environment (?)
