First post, by voltagex
https://ci.appveyor.com/project/voltagex/dosb … build/artifacts
Built from https://github.com/baxterworks-build/dosbox with the latest VS2017 compiler.
The only thing I've cheated on is SDL, which was causing me a linker issue until I rebuilt it with the VS2017 compiler locally. Everything else is from source.
Maybe someone will find https://github.com/baxterworks-build/dosbox/b … or/appveyor.yml useful.
If anyone has any particular patches they'd like applied, let me know.
