Dosbox on the Zipit Z2
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby ignatius » 2017-12-05 @ 21:39
I cross compiled Dosbox (version 0.74) on my Debian box, using the arm cross compiler.
When trying to execute Dosbox on my Zipit, I get this error:
Exit to error: Could not initialize video: No video mode large enough for 640x400
And, yes, I did follow Mozzwalds tutorial on installing Dosbox on the Zipit Z2. I changed all occurances of "640,480" to "320,240" in the source.
Can anyone shed some light on this?
Thank you much.
Also: I did compile and install libSDL with "directFB" and "fbcon" support.
ignatius
Re: Dosbox on the Zipit Z2
Postby Qbix » 2017-12-05 @ 21:49
the text mode screen is 640x400 (the one you startup in)
maybe select a different text mode to startup in.. not sure what the others have for resolution though)
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby ignatius » 2017-12-05 @ 22:03
Ok. Gotcha. What do I change now? I tried changing "640,400" to "320,240", but it still isn't starting.
The Zipit's "native resolution" is 320,240... And, I do have that mode correctly defined in /etc/fb.modes
ignatius
Postby Qbix » 2017-12-06 @ 08:43
tricky. if you don't want to do downscaling, then you have to go for a 200 lines text mode. (ModeList_VGA_Text_200lines)
You need to do some small changes to do the dosbox routines that setup the initial video mode.
Take a look at SetTextLines which gets called from INT10_SetVideoMode which gets called from INT10_Init
Maybe set the value returned from real_readb(BIOSMEM_SEG,BIOSMEM_MODESET_CTL) to have 0x90 present or hack that code in SetTextLines
(and set a mode that has the dimensions that you want instead of the one that has 640x400 dimensions)
(and set scaler=none in options)
So maybe try:
Code: Select all
real_writeb(BIOSMEM_SEG,BIOSMEM_MODESET_CTL,(real_readb(BIOSMEM_SEG,BIOSMEM_MODESET_CTL)&0x80));
INT10_SetVideoMode(0x1);
instead of 0x3 call that is currently in the init function
User avatar
Qbix
DOSBox Author
Return to DOSBox Development
Who is online
