First post, by folavo
I have an ATI 9800 and I was able to run Dosbox 0.61 with OpenGL output but with the latest CVS ( 25-06-2004 ) it crashes with this error:
Fatal Signal: Segmentation Fault ( SDL Parachute Deployed ).
The instruction at "0x5ed26e18" referenced memory at "0x00000564". The memory could not be "read".
I have tried runing it with diferent SDL.DLL files with no luck.
I have tried an older ATI driver and again had no luck.
Reply 3 of 3, by Nomad_AG
I have the exact problem. I have an ATI 9800 Pro, running on Catalyst 4.4. The aforementioned error message is the same down to the last letter. I've tried various versions of drivers and latter DOSBox .61 CVS builds, but to no avail 🙁
