First post, by emendelson
I'm not sure this will ever be relevant to games, but for the project I'm putting together for running Windows 3.11 (including games), I'm trying to modify some code so that I can import from the host Windows clipboard in ANSI encoding. My other projects use clipboard-paste code taken from the old dbDOS project that looks like this:
void PasteClipboard(bool bPressed){if (!bPressed) return;SDL_SysWMinfo wmiInfo;SDL_VERSION(&wmiInfo.version);if (SDL_GetWMInfo(&wmiInfo) != 1) return;if (!::OpenClipboard(wmiInfo.window)) return;if (!::IsClipboardFormatAvailable(CF_OEMTEXT)) return; //fix from CF_TEXT to CF_OEMTEXTHANDLE hContents = ::GetClipboardData(CF_OEMTEXT); //fix to CF_OEMTEXTif (!hContents) return;const char* szClipboard = (const char*)::GlobalLock(hContents);if (szClipboard){// Create a copy of the string, and filter out Linefeed characters (ASCII '10')size_t sClipboardLen = strlen(szClipboard);char* szFilteredText = reinterpret_cast<char*>(alloca(sClipboardLen + 1));char* szFilterNextChar = szFilteredText;for (size_t i = 0; i < sClipboardLen; ++i)if (szClipboard[i] != 0x0A) // Skip linefeeds{*szFilterNextChar = szClipboard[i];++szFilterNextChar;}*szFilterNextChar = '\0'; // Cap it.strPasteBuffer.append(szFilteredText);::GlobalUnlock(hContents);}::CloseClipboard();}
Wengier Wu gave me the fix from CF_TEXT to CF_OEMTEXT that makes it possible to paste upper-ASCII characters. Now I'm trying to adapt this so that I can test for CF_UNICODETEXT and then convert that unicode text to ANSI format for pasting into Win 3.11.
I've spent a lot of time trying to use WideCharToMultiByte to convert the clipboard contents, but I can't make it work. What's especially frustrating is that I once knew how to do this. A few years ago, I found a lot of code online that I mangled into a working executable that saved the Windows clipboard to a specified codepage, but converted it byte by byte.
What I think I need to do is something like this:
#include <atlconv.h>#include <atlstr.h>....const CStringW unicode = (szClipboard);const CStringA szFilteredText = CW2A(unicode, CP_ACP);
But that's as far as I can get...
