DOSBox source code->
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby Peter Swinkels » 2018-1-22 @ 11:52
Hi,
I'm probably overlooking something, but after searching this website and with Google I can't figure out where to download DOSBox' source code. :blush: Where can I find the most recent code? It shouldn't be that hard to find. Thanks.
Peter
Peter Swinkels
Re: DOSBox source code->
Postby Qbix » 2018-1-22 @ 12:03
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Peter Swinkels » 2018-1-22 @ 12:26
Hi, QBix thanks for the quick reply. I just downloaded dosbox-0.74.tar.gz from the link you provided. I just tried to load and run it, but:
1. Visual Studio wants to upgrade the project.
2. Apparently the header files (*.h) can't be found and this results in 606 (!) errors.
3. When searching my C: drive using Agent Ransack a lot *.h files are found...
4. Had to install the Windows SDK 8.1.
I am using Microsoft Windows 7 Home Edition 64 bit and Microsoft Visual Studio Community 2017. The latter has support for C++ projects installed so that shouldn't be the problem. I assume I need to manually change a path reference in the project?
Peter Swinkels
Postby Qbix » 2018-1-22 @ 12:34
aren't there various guides (like a sticky one on in the dosbox general forum, by DOSFreak), which explain in detail how to set things up ?
User avatar
Qbix
DOSBox Author
Postby DosFreak » 2018-1-22 @ 13:21
Haven't tested with the free versions of VS yet but more than likely they don't come with the Windows SDK so you'll need to download that and point VS to the SDK source files.
You do have to jump through a bit more hoops when compiling DOSBox with VS vs Mingw but mainly it's due to using an IDE vs CLI and those differences more than anything.
Check my guide here:
http://www.vogons.org/viewtopic.php?f=3 ... de#p609435
Eventually I'll update the wiki but I've still got work to do on the guide before I'm happy with it.
User avatar
DosFreak
Postby emendelson » 2018-1-22 @ 14:22
Peter Swinkels wrote:Hi, QBix thanks for the quick reply. I just downloaded dosbox-0.74.tar.gz from the link you provided. I just tried to load and run it, but:
Alternatively, you could make your life easier by going here and downloading the complete VS2015/2017 build environment that I put together for exactly this purpose:
viewtopic.php?f=32&t=57519
You'll probably want to update the DOSBox code with the latest SVN changes (the code in my download is only two months old, however), but basically all you need to do is this: open the downloaded folder, double-click the StartVisualStudioProject.cmd file, and, when the project opens in VS2015 or VS2017 (whichever you have installed), choose Build. The exe will be in the Release folder. (Or you can test the build I put into the DOSBox Binaries folder.)
If you prefer to do it by hand, skip the .CMD file and navigate to dosbox\visualc_net, and launch the SLN file.
Tested with VS2015 in Win7-32 and VS2017 in Win10-64. PS: As it says in the other thread, in the download, I've disabled modem, network, and screenshots in config.h, but you can easily re-enable them by editing that file.
emendelson
Postby cyclone3d » 2018-1-22 @ 14:41
The most recent code is NOT 0.74. You really want the SVN package which is the one that is updated. 0.74 hasn't been touched in years.
User avatar
cyclone3d
Postby Peter Swinkels » 2018-1-22 @ 16:35
emendelson, thanks for the link. Your build environment apparently needs Visual Studio 2015. I don't have that version installed and nor do I want to install it if I can avoid it. Do you know how to update your environment for Visual Studio 2017?
Peter Swinkels
Postby emendelson » 2018-1-22 @ 16:50
Peter Swinkels wrote:emendelson, thanks for the link. Your build environment apparently needs Visual Studio 2015. I don't have that version installed and nor do I want to install it if I can avoid it. Do you know how to update your environment for Visual Studio 2017?
As I said in my previous message, I tested this environment with VS2017. When you install VS2017, you should use the option to install the VS2015 SDK or whatever it's called. But I'm not sure you need it. Just let VS2017 update the files if necessary.
EDIT: Also, the other thread very clearly says that it works in VS 2015 or VS 2017. I don't really see how I could have made that more clear, but I've put "or VS 2017" in bold in the hope that it makes the point.
emendelson
Return to DOSBox Development
Who is online
