First post, by ignatius
Hi,
I (successfully?) ported the Ben Nanonote and Dingoo A320 source code for DOSBox to the Zipit Z2. It works fine, except that the display is sideways and is garbled up. I can tell that it works, because I am able to "exit" the emulator and type commands, I just can't see what i'm typing. Is/are there some sort of setting(s) in the dosbox-0.74.conf file that will solve this problem?
Thanks.
EDIT: Here's my ~/.dosbox/dosbox-0.74.conf:
