First post, by robertmo
https://www.dosbox.com/wiki/Building_DOSBox_with_MinGW
libs I used with latest mingw gcc g++ bin 6.3.0-1 dev 4.8.2:
SDL-devel-1.2.15-mingw32.tar.gz
directx-devel.tar.gz
SDL_net-1.2.7.tar.gz
zlib-1.2.11.tar.xz
libpng-1.5.30.tar.xz
libogg-1.3.3.tar.xz
libvorbis-1.3.6.tar.xz
SDL_sound-1.0.3.tar.gz
PDCurses-3.4.tar.gz
Reply 1 of 3, by robertmo
had to use SDL_net-1.2.7.tar.gz cause with 1.2.8 get this:
$ make
/bin/sh ./libtool --tag=CC --mode=compile gcc -DPACKAGE_NAME=\"\" -DPACKAGE_TA
RNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\"
-DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DH
AVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_S
TDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=\".libs/\" -DPACKAGE=\"
SDL_net\" -DVERSION=\"1.2.8\" -I. -g -O2 -I/mingw/include/SDL -D_GNU_SOURCE=
1 -Dmain=SDL_main -MT SDLnet.lo -MD -MP -MF .deps/SDLnet.Tpo -c -o SDLnet.lo SDL
net.c
libtool: compile: gcc -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERS
ION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DSTDC_HEADERS=1 -DHAVE_
SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEM
ORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H
=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=\".libs/\" -DPACKAGE=\"SDL_net\" -DVERSION=\"1.2
.8\" -I. -g -O2 -I/mingw/include/SDL -D_GNU_SOURCE=1 -Dmain=SDL_main -MT SDLnet.
lo -MD -MP -MF .deps/SDLnet.Tpo -c SDLnet.c -DDLL_EXPORT -DPIC -o .libs/SDLnet.
o
SDLnet.c: In function 'SDLNet_GetLocalAddresses':
SDLnet.c:215:69: error: 'ERROR_BUFFER_OVERFLOW' undeclared (first use in this fu
nction)
if ((dwRetVal = GetAdaptersInfo(pAdapterInfo, &ulOutBufLen)) == ERROR_BUFFE
R_OVERFLOW) {
SDLnet.c:215:69: note: each undeclared identifier is reported only once for each
function it appears in
SDLnet.c:223:21: error: 'NO_ERROR' undeclared (first use in this function)
if (dwRetVal == NO_ERROR) {
make: *** [SDLnet.lo] Error 1
had to use libpng-1.5.30.tar.xz or libpng-1.6.0
cause with 1.6.1-1.6.34 get this:
$ make
rm -f pnglibconf.c pnglibconf.tf[45]
gawk -f ./scripts/options.awk out=pnglibconf.tf4 version=search\
./pngconf.h ./scripts/pnglibconf.dfa\
./pngusr.dfa 1>&2
gawk -f ./scripts/options.awk out=pnglibconf.tf5 pnglibconf.tf4 1>&2
rm pnglibconf.tf4
mv pnglibconf.tf5 pnglibconf.c
rm -f pnglibconf.out pnglibconf.tf[12]
test -d scripts || mkdir scripts || test -d scripts
gcc -E -DHAVE_CONFIG_H -I. \
-DPNGLIB_LIBNAME='PNG16_0' -DPNGLIB_VERSION='1.6.18' -DSYMBOL_PREFI
X='' -DPNG_NO_USE_READ_MACROS -DPNG_BUILDING_SYMBOL_TABLE pnglibconf.c > pnglib
conf.tf1
gawk -f "./scripts/dfn.awk" out="pnglibconf.tf2" pnglibconf.tf1 1>&2
rm -f pnglibconf.tf1
mv pnglibconf.tf2 pnglibconf.out
rm -f pnglibconf.h
cp pnglibconf.out pnglibconf.h
make all-am
make[1]: Entering directory `/home/user/libpng-1.6.18'
:>pngprefix.h
depbase=`echo png.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
/bin/sh ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I.
-g -O2 -MT png.lo -MD -MP -MF $depbase.Tpo -c -o png.lo png.c &&\
mv -f $depbase.Tpo $depbase.Plo
libtool: compile: gcc -DHAVE_CONFIG_H -I. -g -O2 -MT png.lo -MD -MP -MF .deps/p
ng.Tpo -c png.c -o png.o
In file included from pngpriv.h:70:0,
from png.c:14:
pnglibconf.h:200:54: error: expected identifier or '(' before '-' token
0
In file included from png.h:485:0,
from pngpriv.h:297,
from png.c:14:
pngconf.h:522:9: error: unknown type name 'ptrdiff_t'
typedef ptrdiff_t png_ptrdiff_t;
In file included from png.c:14:0:
pngpriv.h:804:21: error: operator '!=' has no left operand
#if PNG_ZLIB_VERNUM != 0 && PNG_ZLIB_VERNUM != ZLIB_VERNUM
make[1]: *** [png.lo] Error 1
make[1]: Leaving directory `/home/user/libpng-1.6.18'
make: *** [all] Error 2
Reply 2 of 3, by DosFreak
Check my guide in the DOSBox compilation guide thread. MinGW guides are in the Google Drive link.
SDL_Net 1.2.8
This error started to occur when mingwrt was updated to 5.0.2 I think. My copy of SDL_Net on Google drive removes the functionality that causes the error. DOSBox doesn't use this anyway. It's on my list to ask the SDL_Net dev to add a define for configure for old OS compatibility anyway.
The error does not occur with mingw-w64.
Libpng
Issue there is the ancient version of gawk included with MSYS/Mingw and MSYS2/Mingw-w64. Use a newer version of Gawk from the Internets or my Google drive. Mingw-W64 also comes with an old ver of Gawk so you'll need to update gawk or use a diff patch on libpng. Yet another reason to use Linux to compile since the repos are more up to date.
The above linked guide was okay for the time but definetly shouldn't be used today.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 3, by kjliew
You should really be switching to MSYS2/mingw-w64-i686 for Windows build.
The only optional lib that is missing from packaging ecosystem is SDL_sound. Everything else should have already been available. You don't need to compile libpng, SDL, and SDL_net from source.
If you really want SDL_sound with DOSBox SVN, then compiling SDL_sound on MSYS2/mingw-w64-i686 is also a piece of cake, because all the SDL_sound dependecies libs (for a full-featured SDL_sound) are also available from packaging ecosystem. You also get the latest GCC 7.3.0 from MSYS2/mingw-w64-i686.
MinGW.org does not seem to be maintained and updated anymore. Last GCC version is 6.3.0, and there are chains of dependencies libs to resolve for building DOSBox SVN. Although it is still doable provided one is adventurous enough to go through the process, I would suggest that you spare yourself the trouble and just use MSYS2/mingw-w64-i686.
