First post, by videogamer555
I would like to recommend an option in the settings file, which would allow you to force aspect ratio correction for all video modes, including text modes, not only graphics modes as it is currently. This way the displayed aspect ratio would always be 4:3 if the option was enabled.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
did you try the SVN before making this suggestion ?
Or is one of them not working ?
Water flows down the stream
