First post, by kekko
Hi!
i'm looking for older cvs sources, possibly one of the latest releases before introduction of key mapper. thanks.
Reply 1 of 13, by `Moe`
Then check them out yourself.
You get the original CVS tools and docs from http://www.cvshome.org, and a gui for several operating systems from http://www.wincvs.org/
Reply 7 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
well you should concentrate your efforts on making the mapper better
(e.g reporting specific problems)
It's not going away and compatibility of dosbox has much improved since.
Water flows down the stream
Reply 8 of 13, by kekko
You're right Qbix, but I already submitted my problem 2 months ago:
Dosbox and "matching events"
and the only answer was "yes ok it doesn't work". Since msvc is not supported by dosbox developers I didn't reply to the topic so I don't bother them.
what can I say, I'll try by myself to edit sources in my free time.
thanks anyway.
Reply 9 of 13, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Forget MSVC6. See CVS Builds (once a week) how to compile it using only free tools.
Personally I use MS VS NET 2003, but I tried it as above described as well. It is not that difficult to make it work.
Mirek
Reply 11 of 13, by kekko
last time I tried to compile with mingw-msys it took ALOT of time, and I have an athlon xp 2600+ and half gb ram. no I definitely don't like mingw.
instead msvc is easy and fast(5 min max). Makes smaller builds and the speed of emulation is the same. I alwais gone perfectly with msvc, until that mapper... 😢
Reply 12 of 13, by priestlyboy
Didn't take all that much time for me. I use a P4 with only 256 mbs of RAM and I'm try to optimize DOSBox. :p.
Ieremiou
Helping Debug DOSBox.
Reply 13 of 13, by kekko
To anyone interested, I uploaded latest cvs modified to compile under vc6:
