PowerPC Dynamic Recompiler (patch)
Reply 100 of 117, by samo79
Mmm why do you want to force me to say exactly how much more speed I would like to achieve?
I don't know exactly how much space for optimization it will possible; that's why i asked jmarsh... but even if we could gain only 1 or 2 fps more it will be pretty good 😀
For sure i will not expect the impossible
Reply 101 of 117, by DosFreak
because "I want more speed" is too vague? More speed for what? If someone worked on it with no goal let's say they put 100hrs into it for 2fps....for what?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 102 of 117, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's nice to have more speed for PowerPCs but only theoretically. So it really depends on why you are using this old machine for gaming and why would 1-2 fps actually help? anything below 5fps is almost a matter of a certain system service running at the time or not and not really a good measurement 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 104 of 117, by samo79
@Jmarsh
Thanks for replying 😀
My testing hardware is a Sam440ep Flex 800 Mhz (Radeon 9250) running AmigaOS 4.1
More info about this board: https://en.m.wikipedia.org/wiki/Sam440ep
As a test I'm using the latest version ported to AmigaOS4 by kas1e (with your Dynamic core enabled)
As far as performance goes, according to PCPBENCH the performance's difference between core "normal" and core "dynamic" on my sytem are :
core=normal --- 0.7 (sometimes even 0.8
core=dynamic --- give me a stable 2.7 as a result
There is a big difference in term of performance using Dynamic instead of normal of course, and this is visible not only in that specific benchmark test but also in real games .. but unfortunately not quite enough to play many of that old titles on a slow hardware like mine 🙁
These are my current settings:
fullscreen = false
vsync = false
fullresolution = original
windowresolution = original
output = surface
Reply 105 of 117, by Dominus
DOSBox Moderator
So, the question remains, do you actually want to play on this slow machine (which no matter what won't be much faster) or just be able to play? Huge difference and IMO you are way better off with any newer system if you really WANT to play.
I *do* get it to be able to play. I'm still releasing snapshots of DOSBox SVN for PPC macOS but I definitely do not want to play on my old Mac Mini anymore.
Reply 106 of 117, by samo79
Just playing some more complex game with an usable framerate, for what i can see even a slight improvement could allow the use of slightly more complex games (for example Mortal Kombat or Super Street Fighter 2 just to say a couple)
Reply 109 of 117, by jmarsh
I mean that setting does not even exist in regular DOSBox. Whatever build you're using has other patches/modifications. Since your speed is lower than expected it's probably due to those.
On a 729MHz CPU I get 4.2fps in PCPBench (the regular 640x400 test), up to 4.5 if I turn frameskipping on.
Reply 110 of 117, by samo79
Yes, indeed as i said that settings i've used in config was "experimental" ..
This is the port we actually using:
http://os4depot.net/?function=showfile&file=e … uter/dosbox.lha
Anf that are the default settings we have in our port for Amiga
fullscreen = false
vsync = false
output = texture
texture_renderer = compositing
capture_mouse = seamless middlerelease
sensitivity = 100
waitonerror = true
priority = higher,normal
mapperfile = mapper-0.74-3.map
In my cass, on my little machine in general i only changing the output=texture
-- to use "surface" instead ... this will help a bit on Sam440
About the CPU.. yes we have similar mhz on our PowerPC boards but probably that CPU cannot be exactly compared .. Sam440 uses a SoC processor
Reply 111 of 117, by DosFreak
You'll need to test if the port your are using has regression, since you are also using dosbox-staging patches then you'll need to talk to them about those if those are and issue and you will also need to compare to the the official version of dosbox.
We'd prefer it if you keep dosbox-staging discussions to the dosbox-staging site since one of the maintainers of that projector is banned here.
Not that this is related to your issue but does the port you use still use a "0.74-3" keyboard file?
I guess this port is supposedly still 0.74-3 even with all of the changes? So not using the latest SVN code?
Reply 112 of 117, by kas1e
@jmarsh
My amigaos build is original dosbox + all your ppc patches + sdl2 patch (so sdl2 swith surely may have impact) + cdrom based part from dosbox-staging as it support audio from cd better than in original.
But, to add on that, all lowend custom ppc amiga hardware are crap if we compare it with even old ppc macs or wii, as it done by entusiast in low quanity, and mostly for labor of love than business. As such all the things related to cache's speeds, speed of memory tranfer most of time suck.
Add on top that it controlled by AmigaOS4: not the OS writen by genius, but just additional components and improvements at top of old, BCPL language based, AmigaOS3 from begining of 199x era. There even still some 68k code left which is internally emulated.
So sdl2 patch, custom slow ppc hw, amigaos4 : nothing surprised. And i do not know what samo expect at all with his hardware: stuff which works slow for him, will continue works slow. Be in hope that anyone will spend hours because "i want 1 fps" to have the same slow speed i see no sense.
My PPC machine from othet side are 2ghz ppc and comparable at least by speed with latest ppc macs, and dosbox works good with your jit.
Sure if there possibility to speed things up for cheap, that will be cool, but loosing a lot of time for +0.1 fps make no sense.
But for real, what is need it in terms of ppc support is 3dfx . That surely more important than improve benchmarks on 0.1 fps.
Reply 113 of 117, by krcroft
samo79,
The Pi3B (non-plus edition) at 1.35 GHz allows DOSBox to handle roughly 30,000 cycles, which produces a score of 17.6 FPS in PC Player Bench at 320x200) If we proportionally scale that score down to your 800 MHz system (800 / 1350), we get 10.4 FPS.
But you're only getting ~4 FPS, so what explains the > two-fold reduction? My linear calculation assumes your PPC 800 Mhz performs the same number of instructions-per-cycle as the Pi3, but given your PPC is likely many generations older, my guess is its reduced IPC efficiency likely fully explains this performance gap.
If your PPC's IPC turns out to be less than 1/3rd the Pi3, then the PPC dynrec implementation is even be more efficient than DOSBox's ARM dynrec 😀 (but I haven't dug up those numbers).
Reply 114 of 117, by jmarsh
krcroft wrote on 2020-10-31, 08:12:
The default mode that PCPBench uses is 640x400, four times the size of 320x200. By that comparison the 800MHz PowerPC is kicking the 1.3GHz Pi's butt for IPC.
Reply 116 of 117, by Stretch
For Nintendo Wii, is this patch intended for the source code from https://github.com/dborth/dosbox-wii or from another repo? I get many errors of "(different line endings)" even though I converted the patch to Windows line endings with unix2dos.
Win10 - AMD Ryzen 9 3900 - 16 GB - GeForce RTX 2060S - Sound BlasterX AE5-Plus
Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2 GB - GeForce FX5700 - Audigy 2 ZS
Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - Yamaha YMF724
