Reply 120 of 133, by retro100
Hi! Dosbox for Wii with jmarsh great patches is available.
@jmarsh
Thank you very much for the great Dynamic Compiler patches!
@Stretch
A forked dosbox-wii version with the Dynamic Compiler patches from jmarsh is now available for the Wii (and WiiU).
I have synced the dosbox-wii to SVN r4301 and applied the patches from jmarsh for Dynamic Compiler support. Unfortunately, there is a bug at the Wii version (independent of the patches. The patches works great!). The bug is that the virtual keyboard cannot be used. A real keyboard is no problem.
For more informations see https://github.com/dborth/dosbox-wii/pull/57 and https://github.com/retro100/dosbox-wii.
I also made some benchmarks with PCPBench. With core=dynamic I get a result of 2.9 fps on my Wii and with core=normal the result is 0.5 fps. For the benchmark results see https://github.com/retro100/dosbox-wii/blob/m … rk_Wii_WiiU.txt. A pre-release is also available at https://github.com/retro100/dosbox-wii/releases.
Currently I applied the patches ppc_dynrec.diff and drive_fat_BE.diff from jmarsh. Have I forgotten any patches or are there any other patches that should be added to the Wii port?
Best regards
retro100
