First post, by petob
On 28.9.2004 I tried latest CVS builds (from the net and my own build) on several different PCs with Windows XP Pro and I have found these bugs:
1) Right after DOSBox start Num Lock status is not read, because even when it is on, it is functioning like when it is off - num-pad numbers are doing navigation. Functionality is right only after switching Num Lock off and on.
2) Num-pad comma "." key is not functioning no matter Num Lock is switched on or off.
