First post, by mcbarlo
I have compiled DOSBox 0.62 for MorphOS. It works but I have one big problem. All names of directories and files looks like this: ~1, ~2, ~3, etc. I can access to my data but I must remember his names. In Norton Commander and 'dir' command this problem exists.
Which part of code generates names of dir/files?
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
dos uses a 8.3 standard and hence dosbox.
nothing you can do about it.
(it's what you get from emulating dos)
I think you mean
abcdef~1
abcdef~2
or is it different ? pure
~1
~2
it that is the case post the real filenames here.
Water flows down the stream
Reply 2 of 7, by mcbarlo
I have done screenshot. This is best method to show you problem.
http://www.integradesign.org/temp/dosbox.png
Watch out - slow server.
In the left is my port of DOSBox 0.61, in the right you can see new DOSBox. They're running in the same mounted location.
I hope you understand, my english is terrible. 😒
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
yes that is very curious errror.
The ~1 names are created by the following sourcefile
dosbox/src/dos/drive_cache.cpp
the following link will display all changes in the code from 0.61 to 0.62
you want to look at portion around line 176. maybe reverting that fixes it.
If it does please tell us
http://cvs.sourceforge.net/viewcvs.py/dosbox/ … r1=1.38&r2=1.32
at first i would suggest removing that part.
if that makes it work please post your directory seperator and which type of system is used. (is it linux like/windows like etc)
Reply 4 of 7, by mcbarlo
I remove this part of code - nothing changed.
I use this file from 0.61 (after few fixes) - the same effect.
My system isn't Linux or Windows like but we can tell that is Linux style beacuse I have installed GeekGadgets (Unix env).
Directories in MorphOS:
device:directory/another_directory/file
I saw one more strange thing. All entries is interpreting like dirs.
Reply 5 of 7, by `Moe`
":" is an illegal char in DOS filenames. Could it be possible that DosBox somehow gets the full path and is confused by the ":"? Did anything else change? (dosbox config, system compiler, SDL library, mount commands -- anything?)
Reply 6 of 7, by mcbarlo
I mean problem isn't exists in drive_cache.cpp but probably in drive_local.cpp. Why? I checked what is puted in GetExpandName(). This is ~1, ~2, ~3... I look at this code for short time so I can wrong.
Please help me, DOSBox 0.62 is great but with this bug is makes it completely unusable. 🙁
Are you planning JIT for PowerPC?
Reply 7 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Well, as far as I know, nobody from developers uses MorphOS (just Linux or Windows).
So it would be useful if some programmer working with MorphOS had a look on it and submitted patch if necessary ...
As for JIT for PowerPC: I think all developers are on Intel compatible processors, so my guess is that answer is no (though I did not talk about it with developers).
Mirek
