First post, by bibi.happy
i 'm not a developper, but i want add FOR IN DO command in DOSBOX 0.62
I found cpp source code dor FOR IN DO (freecom source) command but i cannot insert it in source code of dosbox 0.62
Can you help me ??
Thx
Bibi
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
bibi, it's great that you want to help out, but may I suggest that you start with something more simple than adding support for FOR-IN-DO?
E.g. start by changing the COPY command to KOPI. It is a fairly simple change to the code, but you will learn A LOT about how to develop for DOSBox in the process. Next see if you can create say ... ERASE, as an alias for DELETE. Again, fairly simple, but you will learn a lot in the process. Once you have mastered this, you are ready to tackle the larger task of adding FOR-IN-DO.
Also, here are some pointers to get you started:
http://dosbox.sourceforge.net/wiki/index.php? … =BuildingDOSBox
_________________
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
you need to look at the files in dosbox/src/shell/
But please don't simply post the code of another program there. Dosbox has it's own dos and you have to code to its standards.
Water flows down the stream
