First post, by bibi.happy
Hi,
I search a developper that can implement INT21,2B (set date) in DOSBOX 0.62 or 0.61
Can you help me ??
Thx
Bibi
(anthony_openlog@hotmail.com)
Hi,
Can you help me ??
Thx
Bibi
Or DOSBOX 0.63 😉
Thx
bibi
any reason why ?
Water flows down the stream
I have an old 16 bits DOS program (cobol).
With prescott processors, it's very run slowly (many hours to calculate data).
With dosbox, it's run quickly (>40 secondes for the same operation) but this program do use the interrupt 21,2B for many operations.
Bibi.happy
... and what is the problem in the program when date is not set?
Mirek
The data calculated are WRONG ! 😵
odd. i would have suspected that set time would be more critical then.
But maybe the data deals with dates and such.
It's not very complicated to add.
So who knows.
Yes, but I don't know how to add it
can you help me ???
Pleeeeeaaaaaaaase 😉
Maybe i understood the problem wrong, but afaict int21/2b
is implemented (correctly).
Could it be it uses int1a/04, which is not implemented?
wd
Hi,
Int1A,4 : Real Time Clock.. Why not ...
I'm not a developper , i cannot verify if this interrupt is implemented or not ?
With Dosbox, if i launch a DATE.EXE program for set date, dosbox 06.x responding "No Permission to set DATE".
I have the adminsitrator rights in my PC.
Bibi
Qbix: Does DOSBox contain its own virtualized "world clock"? Some programs may want to adjust the clock, and it would be a shame if it did it for the system clock.
Yes, it’s my fault.
dosbox doesn't touch the system time. it only uses to set the date and time on startup (more or less)
So how come you are so sure it has to do with the date?
Imagining your program reads the date (correctly returned by
dosbox) and performs some bin2dec or other conversion that
goes wrong because of a cpu/fpu bug, results would be the
same as a bug in the date function.
It would really help to examine the program, if this is not possible
for some reason, maybe you could provide a more complete
report about what happens exactly, and what should happen.
wd
It could also be a Y2K bug 😉
Yes, it’s my fault.
Do you know if in a new release of dosbox (0.64), the Int21,2b or/and Int1A,4 will be implemented ?
Thx
Bibi.happy 😵 😵 😵 😵 😵 😵 😵
Is the CMOS clock emulated? I mean... can a program read/write ports 70 & 71h and read the CMOS status?
Hi,
I have the ASM source code of my program for the set date .....
Is it compatible ??
name $_date
dos_set_date equ 2Bh
dos_get_date equ 2Ah
msdos equ 21h
no_error equ 0
invalid_date equ 1
masque_ascii equ 0F0Fh
base_10 equ 10
annee_debut equ 1900
modulo_week equ 7
premier_janvier equ 0101h
an_2000 equ 2000d
masque_bissextile equ 3
mars equ 3
param equ [bp]
w_erreur equ word ptr [bx]
w_date equ word ptr [si]
w_week equ word ptr [bx]
w_day equ word ptr [bx]
pile_s_date struc
s_date_Save_bp dw ?
s_date_ret_adr dd ?
adr_of_date dd ?
adr_of_err dd ?
pile_s_date ends
_user segment byte public 'CODE'
assume cs:_user
public s_date
s_date proc far
push bp
mov bp, sp
lds bx, param.adr_of_err
mov ax, no_error
mov w_erreur, ax
lds si, param.adr_of_date
call conv ; Conversion jour
mov dl, al
call conv ; Conversion mois
mov dh, al
call conv ; Conversion année
mov cx, ax
cmp cx, 50h
jb s_date_an2000
add cx, annee_debut
jmp s_date_suite
s_date_an2000:
add cx, an_2000
s_date_suite:
mov ah, dos_set_date
int msdos
cmp al, no_error
je set_date_exit
mov ax, invalid_date
mov w_erreur, ax
set_date_exit:
pop bp
ret
s_date endp
_user ends
thx
Bibi
Depending on conv this should not raise problems.
Int21/2a/2b are implemented.
wd
