First post, by Tronic
I have PCBoard running inside dosbox 0.63, on Linux. It initializes the modem fine and sits there waiting for calls. However, when I telnet to it, telnet connection is made but dosbox never talks anything via telnet. It seems completely dead. When PCBoard finally is terminated and it closes the port, the telnet connection gets disconnected.
Have I missed something or is this just a bug? Which kind of debug data should I collect?
SHELL:Redirect output to COM2
Modem Sent Command: AT
Sending OK
Sending OK
Modem Sent Command: ATZ
Sending OK
Note: nothing about incoming telnet connection.
Background: I had to set "Force NON-16550 usage: Y" in order to make PCBoard hear what the modem is responding (OK).
