First post, by MiniMax
Rank Moderator
Moderator
I have noticed that many DOSBox users have problems getting their games to run in full-screen mode. It seems very much like a hit-and-miss affair?
The switch from 'fullwidth'/'fullheight' to 'fullresolution' in 0.62(?) probably do not help either, since searching the forum either turns up incorrect answers (for fullwidth/fullheight) or no answers att all (for fullresolution).
Looking at the configuration can also be confusing:
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullfixed -- Don't resize the screen when in fullscreen.
# fullresolution -- What resolution to use for fullscreen, use together with fullfixed.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# hwscale -- Extra scaling of window if the output device supports hardware scaling.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
fullscreen=false
fulldouble=false
fullfixed=false
fullresolution=1024x768
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,advmame2x,advmame3x,advinterp2x,interp2x,tv2x.
frameskip=0
aspect=false
scaler=normal2x
I am sure it makes sense from a developers view to separate the settings into an SDL-section and an Render-section, but for the end-user it does not make sense. Or?
E.g. if the Render has to do with the quality of the graphics (scaler + aspect), would it not also make sense to move the 'fulldouble' setting into the Render section?
Similar, why not split the 'autolock' and 'sensivity' into a separate Mouse-section? Or at least lump them together with 'mapperfile' into an IO-section?
And - while we are at it - 'fullscreen', 'waitonerror' and 'priority' should be moved to the DOSBox-section.
After all this, the SDL-section can be renamed to '[ screen ]' and be trimmed down to just:
[screen]
fullfixed=false
output=surface
hwscale=1.00
Expand on the comments (because I still do not understand their relations) and perhaps more gamers will be able to enjoy their games in true fullscreen mode.
_________________
Reply 1 of 2, by robertmo
it's in the order dosbox starts up the internal systems.
I didn't like the order too at the beginning, but since i know this^ I like it a bit more.
Other thing is that what is said in "dosbox guides" "how to speed up dosbox" should be enough for most people. If you bought a crappy hardware or don't know how to configure it, you won't be able to set dosbox.conf right. There are just too many otions even for a good GUI. And definitely editing dosbox.conf will neven be as easy for noobies as even a poor GUI. So in my opinion this problem should be solved by a GUI.
Reply 2 of 2, by robertmo
I have a nice idea for a GUI but I think it won't be possible to use it in D-Fend cause of the way it works.
1)
RESOLUTION: original, desktop, ____x____, ____x____, ____x____
original does:
fullfixed=false
desktop does:
fullfixed=true
resolution=0x0
____x____ do:
fullfixed=true
resloution=____x____
2)
GUI tab for screen should have two sections:
Window mode
-hwscale
(hwscale should be grayedout when output=surface)
and
Fullscreen mode
-resolution
-fulldouble
3)
Other options should be in a common section
aspect
scaler
output
