First post, by rg_pablo
Hi guys,
I post here because I'm confused if it's a bug or not, I didn't find any solution for the problem...
The problem is dosbox doesn't work at fullscreen for me
My configuration file, /home/user/.dosboxrc:
fullscreen=true
fulldouble=false
fullfixed=false
fullresolution=1680x1050
output=surface
hwscale=1.00
autolock=yes
sensitivity=100
waitonerror=true
More data:
rootito@scabito rootito $ dosbox
CONFIG:Loading settings from config file /home/rootito/.dosboxrc
DOSBOX:Unknown machine type auto
ALSA:Client initialised [65:0]
MIDI:Opened device:alsa
Setting the machine to type=vga didn't work too...
Dosbox is running .dosboxrc fine, not another configuration file.
X server's problem? I don't think dat, because many games runs properly at full resolution
The system is Gentoo, dosbox 0.63.
Any solution will be appreciated.
Regards,
Reply 2 of 2, by rg_pablo
Thank you!!!!
I've been waiting for months 😀
The problem was overlay, the fullfixed I tried to true obviously...
I think many people have the same problem, seeing at another posts...
Thank you very much.
