First post, by ribbon13
Is long filename support something that will be seen in dosbox eventually?
Reply 1 of 7, by eL_PuSHeR
I doubt it just because real ms-dos didn't have any LFN support. Maybe Qbix will jump in and shed some light on this. In my humble opinion, I find long filenames under ms-dos a nuissance; some problems may even arise using them for real ms-dos apps or games.
Reply 2 of 7, by HunterZ
I count DOS 7 (the version that Win9x/ME sits on top of) as "real DOS", although it only supports long filenames when Win9x/ME is running.
I'm not sure why LFN support would be especially useful though, as the vast majority of DOS games (if not all of them) don't require it.
Reply 3 of 7, by MiniMax
Rank Moderator
Moderator
Yep - the standalone DOS in Win95 do not support long names. The "MS-DOS prompt" do.
    34.67 KiB
    MS-DOS prompt running with Win95 shows and supports long names.
    20.73 KiB
    124 downloads
    Stand-alone DOS from Win95 do not understand long names.
_________________
Reply 4 of 7, by DosFreak
I remember using LFNDOS back in the day. Support could probably be added in but I don't think DosBox needs it.
LFNDOS Supported API's
Notes
SUPPORTED API FUNCTIONS
For those of you who are more technically minded, LFNDOS provides the
following functions (limitations are in brackets):
INT 21/AX=7139 Create directory
INT 21/AX=713A Remove directory
INT 21/AX=713B Change directory
INT 21/AX=7141 Delete file
INT 21/AX=7143 Extended get/set attributes (subset only)
INT 21/AX=7147 Get current directory
INT 21/AX=714E Find first file
INT 21/AX=714F Find next file
INT 21/AX=7156 Rename file (to same directory only)
INT 21/AX=7160 Truename
INT 21/AX=716C Create or open file
INT 21/AX=71A0 Get volume information
INT 21/AX=71A1 FindClose
INT 21/AX=71A7 FILETIME to DOS date/time (subset only)
INT 21/AX=71A8 Generate short name (subset only)
Another limitation is that you can only have ten open searches (AX=714E) at
one time. If a program tries to open too many simultaneous searches, LFNDOS
will print an error message.
The following functions are currently NOT implemented - calling them will
cause an error:
INT 21/AX=710D Reset drive
INT 21/AX=71A6 Get file information
INT 21/AX=71A9 Server create/open file
Make your games work offline
Reply 6 of 7, by ribbon13
That's why all the patent/copyright breaking software I write uses the name of some dead person from some island that never signed the berne convention. =D
Seriously though, since dosbox is independent of the filesystem its run on, as it ties to the host OS how would the be a problem?
How can you really patent last two characters are ~ and a number, save the rest of the info elsewhere? Considering there were esoteric filesystems before FAT32 that supported long filenames would that fall under prior art?
and care to point that patent out?
in the USxxxxxxx form
like
http://l2.espacenet.com/espacenet/viewer?PN=US6399828
sad day...... the-hive has been down for a month... 🙁
