First post, by Akuma
Compiled the lastest SVN but I'm getting an error: Can't find matching event for hand_debugger. Now everything works except the debugger. (its compiled with --debug=heavy)
Might I be missing a dependency ?
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
tried removing your mapper file ?
Maybe post your config.h file (or at least check if C_DEBUG is set there)
and yes, check what ripsaw wrote as well
Water flows down the stream
Reply 3 of 4, by jmarsh
When you save a mapper from a non-debug build the mapping for "break to debugger" isn't written because it doesn't exist for that build. Then you loaded that same mapper in a debug build, hence the warning about the event not being found.
Reply 4 of 4, by Akuma
My bad,
  1. Did not have libncurses-dev installed
  2. Script should have had ./configure --enable-debug=heavy && make
  3. 'make clean' did not remove ./src/dosbox
So the non-debug version was copied over the old debug version.
Which meant that I was running a non-debug version with a .conf .map from a debug build.
Problem is solved, thanks guys.
Should make clean remove ./src/dosbox ?
