First post, by XulChris
- Member
I am thinking about recoding the tab completion part of dosbox to behave more like readline(). By this I mean that pressing TAB will print out a list of available matches, and only completes the match if 1 match is found. Additionally, if the match is a directory, a trailing / will be added to the command line.
What do you guys think?
