First post, by DosFreak
I was trying to figure out the problem with Mechwarrior 2: Mercenaries unable to detect the CD and I ran across this documentation: http://www.woodmann.com/fravia/rcgcd.htm from this project page http://www.woodmann.com/fravia/project4.htm
Following is testing done with DosBox 0.63
MERCS.EXE
Just game directory loaded and executing mercs.exe
MISC:MSCDEX: INT 2F 150B BX= 0000 CX=0000
MISC:MSCDEX: INT 2F 1500 BX= 0000 CX=0000
with mount D D:\ -t cdrom -label MERCENARIES -ioctl
Same with mount d d:\ -t cdrom
MISC:MSCDEX: INT 2F 150C BX= 0001 CX=0001
With IMGMOUNT
Okay so the way I understand it:
150B=Drive Check. Check Drive #.
1500=CDROM Installation Check. Checks # of CD-ROM drive letters used and starting drive letter.
150C=Get MSCDEX.EXE version.
Okay, so on all three NO CD Support, Mount with CD support, and IMGMOUNT in DosBox loaded I get BX=0 and CX=0. Which to me is saying that DosBox does not support these values?
Now with 150C we have BX=0001 and CX=0001. Since DosBox only posts 150C when Mount/IMGMOUNT is loaded and it gives it a value of 1, I'm assuming that it detects MSCDEX but I am unsure what 0001 means. According to the documentation I am reading 0000h=versions of MSCDEX.EXE prior to 2.00 but here we have 0001 so I'm assuming that DosBox is reporting v1.00 Mscdex version?
Make your games work offline
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
i think those would be better answered at the general developpers hangout ?
the registers displayed are the registers that are brought in by the caller.
it are not the answers of dosbox.
Water flows down the stream
