First post, by Darkfalz
Would it be possible to statically link the needed dlls into the DOSBOX executable? The folder is getting rather crowded... 😀
libogg-0.dll
libpng12.dll
libvorbis-0.dll
libvorbisfile-3.dll
SDL.dll
SDL_net.dll
libogg-0.dll
libpng12.dll
libvorbis-0.dll
libvorbisfile-3.dll
SDL.dll
SDL_net.dll
No. These few files are no problem (look into windows folders to see what are crowded folders 😀 ).
But there is a more important reason against it: It would not be possible to replace a DLL by another one in case of problems (this is definitely being the recommended thing to try with SDL.DLL when DOSBOX crashes while startting).
Mirek
I have to agree with mirekluza.
If you personally prefer statically linked libraries compile your own copy of DOSBox.
Get the source code of DOSBox as well as of the libraries you want to link and compile the libraries as static libraries and link them with DOSBox. I did this with SDL, SDL_net, libpng and zlib.
As for public releases I don't recommend to link them statically.
It was quite a work to get to link dynamicly under mingw.
the authors of the libs didn't always have a good makefile.
Water flows down the stream
The only build that is mostly static linked is my builds.
and since Libvorbis is rarely updated it's not like it's a big deal to have it static linked or not.
But the main DLLs that are gladly not statically linked are SDL and SDL_net
The rest I could care less.
/Ieremiou
Ieremiou
Helping Debug DOSBox.
Yeah, the vorbis dlls are what most bother me. Just seems they have nothing to dow ith emulation.. what are they for anyway? Recording streams to ogg format? Why not just wav?
wrote:Yeah, the vorbis dlls are what most bother me. Just seems they have nothing to dow ith emulation.. what are they for anyway? Recording streams to ogg format? Why not just wav?
IMGMOUNT enables mounting CUE sheets with OGG files. The information is well hidden in our readme
IMGMOUNT A utility to mount disk images and CD-ROM images in DOSBox. IMGMOUNT DRIVE [imagefile] -t [image_type] -fs [imag […]
IMGMOUNT
IMGMOUNT DRIVE [imagefile] -t [image_type] -fs [image_format]
-size [sectorsbytesize, sectorsperhead, heads, cylinders]
imagefile
location of the image files to mount in DOSBox. The location is on a
mounted drive inside DOSBox. CD-ROM images can be mounted
directly as well. They don't need to be a mounted drive.
-t
The following are valid image types:
iso: Specifies a CD-ROM iso image. The geometry is automatic and set for this size. This can be an iso or a cue/bin.
Yes, it could be better documented. 😀
Mirek
