First post, by ih8registrations
Howdy ho,
Apply from root dosbox directory "patch -p0 < optimize.diff".
Optimizations to normal_loop, some pic routines, and a little touch up to the mixer handler. ie. speedup isn't cpu core specific.
Rearrangment for fallthrough to the most common paths and ridding of jumps mainly.
Timed with rdtsc and just used variables to track common paths.
Enjoy!
Oh yeah, speed up is relative to an athlon xp /w 256k l2, so something like an athlon 64 may not see as much an improvement since it handles thrashing better.
    optimize.diff
    11.81 KiB
    274 downloads
Reply 2 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
well my guess would be that most "speed" comes from the fact that you reduced the amount of gfx events.
Water flows down the stream
Reply 5 of 10, by avatar_58
What game would benefit from 10% increases? 😕 Anything that is too "slow" would only cause sound stuttering really. Therefore you would need much more than 10%.
Reply 8 of 10, by DosFreak
Speaking of speed increases....
I reinstalled 2003 Server today and benchmarked DosBox, Now I can use a few thousand more cycles in 2003 than I could on 2000. Hopefully it was some driver or software slowing down 2000 and not some difference between 2003/2000. I'll True Image my system and revert back and see if it's the same.
Make your games work offline
Reply 9 of 10, by icemann
Wonder what the cycle difference is between win98 and XP. I was using 98 right up until midway through last year and I haven`t noticed any difference really since the change.
Two stones, two crosses, the rest is just icing. - 7th Guest
