First post, by JHawx
- Newbie
While tryeing to run wing commader: privateer, you receve following message:
"protected mode driver is not responding to EMS funktion calls.
Make sure your EMS driver is not configured with the NOEMS option.
If it is, replace the option "NOEMS" with "RAM" "
Is it possible to configure this type of ems memory emulation to dosbox? 😈
Also some other ideas for dosbox:
.bat kind of commands. I would like to do .bat type of selector that would mount my selection of drives. also "type" command from file would be great.
so in basic simulation, i would create menu.txt that would be shown from beginning of dosbox.
autoexec.bat
" type z:\menu.txt"
and after that z: would contain following bat files:
"z:\dir
1.bat
2.bat
3.bat etc..."
1.bat has commandline
"mount x c:\games\oldies\tetris
x:
tetris.exe"
2.bat has commandline
"mount x c:\games\oldies\monopoly
x:
monopoly.exe"
and so on...
But these cannot be done with corrent emulation. So type command and .bat type of solutions could be really welcome add to dosbox. 😅
