First post, by GreatBarrier86
- Newbie
Hi,,
I'm just wondering how you are supposed to apply these CVS Diff patches to dosbox. Is there some sort of tool you use to do it?
Thanks,
Jason
Hi,,
Thanks,
Jason
patch it's called
http://unxutils.sourceforge.net/
or use winmerge or so.
dunno Some windows user can probably tell you more about it
Water flows down the stream
oh good. thanks a lot...really appreciate it!
IBM ThinkPad X40
1.2Ghz with 2MB L2 cache
1.0GB DDR2 SDRAM
Intel 852/855GME Graphics Media Accelerator with 64MB
12'' LCD Screen
SoundMax Integrated Audio
Peas Pobie!
actually, could somebody help me with the cmd line to type in in order to merge the diff file? I have no idea what to type
IBM ThinkPad X40
1.0GB DDR2 SDRAM
12'' LCD Screen
Peas Pobie!
decompress cvs in a directory;
put patch.exe from unxutils and the .diff into that dir
run:
patch -p0 <filename.diff
where filename is your patch
i tried that but when i entered that cmd line, nothing happened...it just went to the next line, but did nothing. Pressing enter only brings me to the next blank line
IBM ThinkPad X40
1.0GB DDR2 SDRAM
12'' LCD Screen
Peas Pobie!
Sounds like something is wrong with the <filename.diff part that is causing it to get input from the console (keyboard) instead of the filename.diff file.
try:
patch -p0 -i filename.diff
thanks for your help. So all i need would be the patch.exe and the diff file?
IBM ThinkPad X40
1.0GB DDR2 SDRAM
12'' LCD Screen
Peas Pobie!
