First post, by Leolo
- Member
Hi!
I'm really ecstatic right now, I've just found your DosBox binary (2005-04-29) and I'm playing absolutely smoothly the cdrom version of Tie Fighter in high resolution! Yay! I never thought this could be possible!!
This miracle worked after setting timesynched=true:
But there's one thing I don't understand: why does the window say 70 FPS? My LCD monitor is set to 60 Hz, not 70. Where does the "70 FPS" figure come from?
PS: I'm using an Athlon XP 3000+ (Barton core) with 512 MiB of DDR SDRAM and Windows XP SP2.
Kind regards.
