First post, by Dominus
DOSBox Moderator
- DOSBox Moderator
Hi, with (almost) current CVS Dosbox crashes on exit when (large?) diskimages are mounted.
The disk image I have is about 500 MB big.
When I close dosbox either by pressing the x (right side) or by doubleclicking on the icon (left side) it crashes.
When I type exit it closes down in orderly fashion (only that doesn't work if you boot from the image).
