First post, by cyberwalker
I have recompiled the source in VS2005 successfully.
But Borland's TASM.exe and Microsoft's CL.exe failed
to run against my generated DOSBOX. After tracing into
the source code, I found that it stopped in file function stat().
This is caused by DOS INT21H routines that use full
path to access devices like CON and NUL. Maybe DOS INT21H
can verify file name by looking up the device table before file
operations.
I hope this information will be helpful.
    dos_files_cpp.diff.txt
    1.24 KiB
    151 downloads
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
hmm yes that is a tricky problem
our devices detection doesn't work that well on all file operations.
Thank you for reporting it about that stat. I think that one might be fixable
Water flows down the stream
Reply 2 of 3, by cyberwalker
Thank you for your attention. I have uploaded patch code for testing.
