First post, by eobet
This applies to enhanced mode only, with XMS/EMS off and I get the message in both 0.63 and CVS on both 3.1 and 3.11.
I searched the forum, but nobody mentions this at all. Do I need to dig up my MS-DOS discs and install that as well? (Then I'd need to search the forums on how to properly do that also, I guess.)
Btw, I'm trying to get Battle Isle 3 (2220) working under Windows 3.1 in DOSBox, as I can't get it to work in XP.
Reply 1 of 11, by eL_PuSHeR
Open a separate thread, in the proper section, then.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 11, by eobet
Sorry, but getting Windows to work takes precedence over the game and that is why I made this thread.
I suspect that the thing I'm doing wrong is very basic, though, since nobody else have reported this.
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
which version of windows do you have (seriously) is it some weird language ?
as dosbox cvs has been tested with 3.0 3.1 3.11vwf english though
probably the german versions have been tested as well
Water flows down the stream
Reply 5 of 11, by eobet
Arg, I found out what the problem was!
As I said, it was something very basic: I had turned off the Soundblaster emulation (and also the GUS) in the config file. Turning it back on made Windows boot normally.
I also installed the S3 drivers now to get 256 color graphics (16-bit doesn't work, I assume?), though I still have to find Soundblaster drivers...
However, Battle Isle gave me an "error 21", whatever that is. Guess I'll wait for a few more versions of DOSBox, then try again.
Reply 6 of 11, by DosFreak
Yeah, error 21 is a known issue with Windows 3.x and DosBox. No solution as of yet, unless you want to use Qemu,VPC,Vmware.
Make your games work offline
Reply 10 of 11, by eobet
I found SB16 drivers on www.soundblaster.com but not Soundblaster Pro 2 (which is what I used to have). Windows 3.x only includes Soundblaster 1.0 and 1.5 drivers, I think.
Anyway, what is "Error 21"? I tried to search the forum, but couldn't find any information about it?
