First post, by Stainless
I started out with dos. I notice there is no config.sys to modify for DosBox. Like Buffer=40 and Files=40 DOS=HIGH,UMB etc.. I'm trying to set up a Fossil driver for a game I'm trying to play on my BBS its a doorgame terminal program that I use through Qmodem under dosbox. Reason: Can't do it anyother way. Anyway this particular fossil driver needs me to install a DEVICE=C:\BNU.SYS file with command line parameters and I cannot do this. Is something like this in the works or has someone incorporated a config.sys to use with DOSBOX? If so please message me. Thanks guys keep up the good work.
Come to Rat's Nest BBS 😉 Telnet to ratsnest.synchro.net. Lots of door games to play.
